Dazzler .40
Kit is very easy to build. If you use a hot engine like an OS .46 FX, then you'll want to re-engineer the tail featehrs and make them solid instead of built up, this stregthens them and also omits any tail weight that you might have to add. Just so you know, the Uproar .40 is almost identical , um doesn't have turtle deck, but is cheaper. Good luck.
