RCU Forums - View Single Post - need simple answer to carburator needles
Old 01-15-2010 | 12:38 AM
Bonified Wingnut's Avatar
Bonified Wingnut
Default RE: need simple answer to carburator needles
nrad ..An engine running at low RPM's runs better on a leaner mixture..so when you are at an Idle the low speed needle is the one controlling most of the fuel flow(if not all). And when you are wide open it has almost no effect.- BW
