RE: Money dissapears so fast!
JPX 21 with a JP3 and you will never want another engine. i get over 8 min a tank i pit at 8 min. the only thing is RUN 20% fuel in it unless you buy another shim for it because it wont last much over 2 gallons if you run 30% also you will have to replace bearing after about 4 gallons they start leaking. a guy named Alan Burtan does them really cheap, he in stalls ceramic bearing, the best you can buy, for cheaper than the bearing coast by them selves. let me know if you need parts for this buggy and i may have a used part that ill sell cheap maybe just coast of shipping. i do not use any parts that just fit the x1 so they just sit in a box. including two chassis one that has a good bit off use but still in pretty good shape and one with maybe 3 gallons on it and i always ran skids with that chassis, looks almost new.
