RE: How to select correct retracts
Pretty much in that order, you get the kit, find out what you want,(IE-functional oleo's or just wire) and get a set of retracts that give you the proper weight rating and angle deflection required, either 85 degrees or 90 degrees. The good thing is robart and century jet bolth make AT-6 gear for the topflite kit. So you can just get some premade and setup for it.
