RE: ESM LA-7 From VQ Warbirds
Rudder is perdrilled but you have to drill the trailing edge of the vertical for the hinge. I would most likely change to the larger robart hinge myself especially if i were using a gas motor. The cowl slips over the fuse and it is a little adjustable if you want. So you may be able just to move the cowl a little forward....
Ty
