RE: Deception Build
Nice work.
I never did understand Jim's note on the stab for the fuse side cutout. I mean, the stab is symmetric about the root - zero dihedral except for taper on either side. The cutout needs to be slightly smaller than the size of the capped stab but not much. Certainly not the dimensions of the sheeted core without the LE/TE's attached. In any case, there is also the FG cloth to take into account if so desired. I can't recall if Jim suggests something for that joint. I used glass cloth to the fuse sides on the stab and to the fairings on the wing.
I guess a cut is a cut.
Ed, your B&D's must be pneumatic, right? If not, I need to see how you do this.
David.
