RCU Forums - View Single Post - Battery connectors
Old 01-16-2010 | 08:30 AM
astropuppy
My Feedback: (23)
Default RE: Battery connectors
ORIGINAL: can773
The 4mm ones you can get with a sleeve like this,
http://hobbycity.com/hobbycity/store...2810pcs/set%29
The bigger 5.5's you can do two things, have both sockets on the battery which have heat shrink on them, but this allows the potential for a reverse polarity connection. Or you slide fuel tubing over the male connector for insulation when you are not using it.
I use the 4mm ones in link from hobbycity, they are cheap, protect from reverse polarity connection, are fully insulated and the sleeve really minimizes any connection spark that you may get.
Any tricks/Tips on how to seat the bullet into the housing after soldering? I have had an awful time getting them to snap in securely. Doing it while the bullet is still warm helps, but I still have difficulty.
