RCU Forums - View Single Post - Aurora 9 flaperon set up
Old 01-16-2010 | 08:15 PM
griesel
Default RE: Aurora 9 flaperon set up
Alan ( way way south of Tucson )
I have a electric Modeltech Magic with 5 servos.
Chl 1 R aileron
Ch 2 Elevator
Ch 3 Throttle ESC
Ch 4 Rudder
Ch 5 L aileron
Ch 6 not used
Ch 7 Tail wheel steering - Battery
I would like to use switch E to do the following:
Down position: Ailerons normal 0 degrees
Middle position Ailerons up + 7 degrees
Upper position Ailerons up +14 degrees
This gives two positions for stable landings with a higher angle of attack for
no bounce and less floating landings.
I have it programmed now, using camber, for:
Down position 0 degrees
Middle position 0 degrees
Upper position +7 degrees
I just am having a hard time getting 3 positions like I have with my
7202's and DX7.
