RCU Forums - View Single Post - Spun bearings
Old 01-16-2010 | 08:17 PM
Scota4570
Default RE: Spun bearings
OK, Locktite 620. There is proabably a thousandth play in the seat. Would it be a good idea to use the electric pencil/engraver to give the locktite some "tooth" , center the bearing and restore the press fit?. It is polished bright with a coined finish right now. Should I use my dremil to skuff the finish of the bearing? It has covers right now that I will remove later. That would keep the grit out.
For once I have documented every step of this conversion with photos. I'll post them to my website and share it when the project is done.
Thanks for the help,
Scot
Amended, "There is proabably a thousandth play in the seat." It is more like .006 per side. I measured it with a dial indicator. I spent a while learning about "retaining compounds" Great stuff, I did not know they existed. It loks like I should keep the block warm for a couple of days before I mess with it to get maximum strength.
