RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 01-16-2010 | 10:20 PM
  #332
FlyEng
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: NJRCFLYER2
Does anyone know if the pipe and header for a Mintor 170 will work for the Syssa?
We used a Macs header for the OS 140RX and it fit nicely. It was only necessary to open up the bolt holes a little bit. If I remember right, the OS header would fit the Mintor, so it probably would work. As for the pipe, it depends. ES makes pipes that are a little different for gas engine applications. I think Ed Skorepa refers to it as a reversed flow pipe. I don't have all the details, but you could email him from his website and ask. A glow engine pipe will probably work, however if it's a CF pipe, keep in mind that the exhaust from a gas engine is hotter than a glow engine. THe ES pipes can take it, not sure about every other brand.
Thanks for the info. I'm a long way from final set up and I'm just checking options. I'll be very happy to just copy what others have done and and have proven to work. Anyway, isn't that the best form of flattery.
