ORIGINAL: Greg Wright
Why don't you just use your throttle stick to adjust your airspeed. Da simple solution isn't it.
Simply using throttle is not any kind of solution.
At full idle, if the plane is not going slow enough for your liking, you can't throttle back any more. Plus, having a smaller pitch will help act as an airbreak, just using your throttle won't.
