Ryobi sensor help
I bought a electric ignition converted 31cc ryobi engine off rcu and ran into a problem, I will do my best to explain it,
I have narrowed it down to the Sensor and was wondering if any sensor would work as long as the magnet was aligned with the sensor? what the bad sensor is doing is it will spark with i turn off the attached on/off switch to discharge. I can get it to send a charge from the battery but it does not return the spark when the prop is spinning..any suggestions? will any sensor work? Thanks for your help!
