Volcano S30 Transmission Woes
Hi all,
I am new to the RC Nitro world, and am having troubles with my Volcano trans. When viewing the trans from the rear, the left shaft can be pushed in slightly, and the gears will then work properly. If I spin the trans gear where the motor connects for about 3 seconds, the shaft then pops back out towards the rear. The spur gear then will not drive the differential.
So, do I need to order the single gear trans upgrade, or should I dis-assemble the stock trans and fix it(although i have no clue what is wrong)?
PS: there are no stripped gears that I can see.
Merc
