RE: Spun bearings
Making bushings for the bad bearing surfaces sounds good. However, how would you indicate the case in to assure concentricity and horizontal alignment of the crankshaft? The only reference surface you could use is no longer a perfect line bore to the case and would, I am sure, cause more problems than it is worth. Not being critical just concerned.
