RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 01-18-2010 | 07:14 AM
  #340
cmoulder
Default RE: SAP 180 (Syssa Performance)
Bob:
You can make a Y connection between the IBEC and a regulator. The Rx Power lead from the regulator to the receiver does not do anything actively with the signal wire (JR Orange, Futaba White, Hitec Yellow, Airtronics Blue). It's there to provide a path for radios that have DSC (Direct Servo Control) capability, or to allow the use of a bind plug and/or data monitor in the charging jack if it's a Spektrum type setup. So it's just a wiring pass through from the receiver's channel to the Charging / DSC / Bind / Data Monitor port. Thus, when you Y it with the IBEC, the signal is available for the IBEC to look at for ignition power On/Off control, same as it would be if you Y'ed it to a servo.
You could really pick any servo-type connection to Y a regulator to, it's just that things like DSC or binding will obviously only work if the regulator Rx Power lead is connected to the appropriate channel (Normally a designated battery plug location on the receiver).
_____________________________
Ed Alt
Tech-Aero Designs
Okay, I was hoping you'd give your blessing to this practice.
Which brings me to the question of the choke servo, where I am running into the same dilemma with yet another Rx slot needed for that.
Matt has mentioned he is considering using a choke servo with his SAP 180, and I now have a servo I could use (HS-82MG) even though I am not totally wedded to the idea at this point.
Do you plan to use a servo or a choke rod? The way this choke plate is set up - with a spring, as opposed to the open/close butterfly with a detent - there will need to be some sort of catch on the choke rod to hold it closed when choking. This I have not yet figured out.
