Predator V2 gasser standard VS Condor
I'm interested in getting a Predator for AP work. It's a no-brainer that the Condor would be the most suitable heli for the job(more stable in wind?). Looking at the differance between the two, the Condor has a length of 11cm, height of 2mm, and tail diameter 2mm greater than the standard, and whips a larger main blade. Is this slight differance going to make a big impact on my AP work? Couldn't I put on the larger main rotors on the standard(for lifting purposes)? How does this slight differance determine a heli that can do 3D(standard) and not(Condor). I'm just thinking if the AP doesn't pan out, would I be stuck with a heli(Condor) thats only good for that?
Does the 231cc really run smoother than the 26cc? Or have they fixed that issue with the V2's ?
Cheers,
Keith
