RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 01-18-2010 | 12:10 PM
  #344
cmoulder
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: MTK
I currently use a nyrod. I'm wondering if we used a short length of beadchain attached to it and a cut a small vee on the outer nyrod, then we could bring the rod out to choke, and slip the beadchain into the vee to hold it closed. There's got to be an easier way
Matt[/b]
Since the choke rod hangs down, it would be possible to put a small hook or eyelet in the end of the choke rod and attach a little weight to it.
A little funky, but it would work.
The choke servo sounds nifty, but with all the vibration I could envision servo gears wearing out quickly and failure of the servo lead wires from constant flexing.
