RCU Forums - View Single Post - inches to degrees
Old 01-18-2010 | 01:47 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: inches to degrees
Its going to be a formula...remember that geometry/algebra you thought you would never need Essentially think of your controle surface as a Isosceles triangle where the length (chord) of the control surface is two sides of the triangle. and you want to know what the length of that other side (your deflection in one direction) is. Now, I have found a web site if your so inclined to figure it out it is here: http://www.ajdesigner.com/phptriangl...erimeter_s.php
However if this plane is an OMP profile 3D flyer. Max that sucker out, dial in a good bit of expo and go have fun with it.
