RCU Forums - View Single Post - Proud Bird Construction Thread
Old 01-18-2010 | 10:01 PM
  #142
sahartman21
Default RE: Proud Bird Construction Thread
Concerning health effects:
I use a respirator when painting with KlassKote and when using automotive paints. Both are known for health effects so use a respirator. I got mine at Harbor Freight for about $25.
Wet sanding with 2000 grit sand paper doesn't take off much paint. I use it primarily to knock off the dust.
After the wet sanding I will use some white compound and a small buffer. This step gives the depth that you see in a car finish.
I've used Hobbypoxy and SuperPoxy in the past. The automotive type paints go on about the same.
