RCU Forums - View Single Post - Battery connectors
Old 01-19-2010 | 07:25 AM
tonye5797
Default RE: Battery connectors
I use an soldering iron to solder the wire into the bullet.
I heat the bullet so the solder pools inside, then put the wire into the pool. Remove heat and hold steady.
Then when it cools to around 50deg, just touchable, i put it into the plastic conector, and then press it past the clip.
