RE: US 1000 build
Woops! I unpinned fuse from plans and found that the fuse tops was not completely into the fuse sides. I don't know if pic is good enough to see but about 1/16'' is sticking above towards the back on one side.Only about 2'' of the aft part of fuse top is bad. Will this create a problem? The book says to sand flush. Do I sand flush and reinforce on inside? I tried to break loose but it will break other things first. Joint seems very strong.
Wayne
