RE: New CDI - opensource project JMJ and Bigboat
Rob..
I noticed one other thing with the timer board..when the magnet is approaching the hall effect it turns on and makes a spark...if that is normal operation, ok.. but to compare it with my systems I make, the spark waits till after the magnet leaves the hall effect. Not a problem really.. will adjust timing position manually the extra 10 degrees of rotation to compensate for the early trigger if needed. Just thought I'd ask..
John
