ORIGINAL: N7OR
New servo on the way. Still not sure how to get the D.O.A. servo out of the foam fuselage. Appears to be glued in place? Hate to tear up the area around it so the new one doesn't fit tight.
sorry I couldn't reply before now, but I'm glad someone else did! It's just soft caulking and easy to cut out. You can pull the remainder out after you remove the servo.
I had to replace my bomb drop servo. I forgot to set the endpoint and stripped the gears lol.
I'll post some finished shots in a day or two...
Casey
