RCU Forums - View Single Post - Exceed-RC Raptor G2 Keeps Spining
Old 01-19-2010 | 09:15 PM
  #62
yadac123
Default RE: Exceed-RC Raptor G2 Keeps Spining
One thing beginner get it mix up is that RTF means ready to fly, that doesn't mean you do not need to trim and setup the heli. RTF means you do not need to assemble anything at all. Keep in mind that starting with a 6ch is like asking for trouble. You need to be patient because you are trying to learn how to run before you even know how to walk.
Andy
ORIGINAL: Dnutz
hey kaufmann thanks for the post...Man this Exceed Raptor is not at all Ready to Fly out of the box! Mine is all messed up but im determined to get it in the air! Im thinking now my whole problem is the TX...im not sure though. I'll try what you said.
I have messed with the settings of v1 and v2 so much now, last night i couldn't get the pitch right, so i couldn't get it off the ground to check to see if the spinning issue is still there. UUGGGG! I know it will be though cuz i can't get any left rudder to work...but maybe if i get gyro working properly, then it will work!
ORIGINAL: kaufmanp92eb
I found another post about tail wagging. It said to put the dials on top of the remote to 12 o'clock, throw dip 12, turn left dial to 3 o'clock, and throw dip 12 back. I did it and when I turned the left dial to 3 o'clock the red light on my gyro came back on steady. I took it out and no more wagging. WooHoo!!!!!
