RCU Forums - View Single Post - Sebart Wind 110
Old 01-19-2010 | 11:25 PM
  #622
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Sebart Wind 110
Cool, I'm glad I waited!
Found this, too:
Original: Matt Kirsch Electrics Moderator
Many outrunner motors come with a collar that slides over the shaft on the "fixed" end of the motor. The reason for this collar is to reinforce the snap-ring that holds the shaft into the motor when you attach the propeller to the spinning can end of the motor. If you are attaching a prop adapter to the shaft protruding from the fixed end of the motor, then you can remove the collar.
