RE: Please, give me an answer!
If I compare it to a CX2 (check other threads for this), there should be a pod on the control unit that allows you to adjust drift. Reset trim to neutral, and rotate the pod very very VERY slowly until it you get better control. Turn the unit off and on each time you adjust.
