Here's my drifter with foam tyres. I find that the foam tyres heave
heaps more grip and last
heaps longer than rubber. They're also perfect for using at my work where they have tons of grip out on the road and in the carpark, and slide beautifully on the smooth floor inside the warehouse.
Sorry for the explanation being so long.
The body: came with the car and was painted
very poorly in the 'panda' scheme. I stripped it using oven cleaner and then just a touch of thinners on a rag to get the last bits out of the corners. This was my first attempt to paint a body with panel lines around the doors, bonnet, and boot. The cables to hold the pins are made from wire and little silver rings bought from a bead/craft shop, tied together on the inside held with tape. Saves looking for the clips just when you're ready to run... They give a bit more to hold onto and I tried to have the same look as 'actual' bonnet pins
The chassis: It is a HSP item. It's far from a racing chassis but for drifting it is pretty good. The first thing I did was to replace the shocks oil and put in diff oil. This stopped it bouncing around all over the place. The fan on the motor was part of the motor heatsink but the magnets from the standard 540 motor cancelled it out and it wouldn't run. So, I spaced it out with a bit of a 'Tia Maria' lid to spacce it away from the motor and to duct the air onto the heatsink. I bought an Orion Method R 15 turn double wind motor off Ebay for AU$6 (the standard ESC says it will handle down to a 13 turn motor) This new motor is excellent! Now I find the motor barely even gets warm but the ESC gets very toasty so one-day I'll move the fan over the ESC. I swapped the brass bushes for actual bearings that hold the axles which frees it up heaps. I am using a 4600mah Venom battery which lasts well over 1/2hr running flat-out. I used cables on the clips which hold the battery down so I don't lose them too.
