RCU Forums - View Single Post - Evolution .52 Issues
Old 01-20-2010 | 12:02 PM
opjose's Avatar
opjose
Default RE: Evolution .52 Issues
Welcome to the wonderful world of Evolution engine limiters!
This is the "walking needles" problem I've often referred to in other posts.
What you need to do is the following.
- Loosen the "grub" screw on the blue limiter collar fully, then pull the collar straight up and off the needles.
- Pull off the "clips" ( which look like inverted pen pocket retainers ), and bend the clip itself towards the circular retainer, to apply more tension.
- Remove both needles completely.
- Clean the needles of ALL fuel. Get them dry.
- Clean the receptacles for the needles of all fuel, get them dry and clean as well. Make sure you leave NO debris or lint inside.
- Using a microdrop applicator, place an ever so TINY amount of thread locker blue on the threads of the needles and turn them in to the defaults.
- Put the clips back on, now hopefully much tighter...
- Start your plane, tune it up, perform a nose up and down test to check your settings. Get it tuned perfectly on the ground.
- Now if you wish, re-insert the blue collars, with the pin at the center of the adjustment arc.
This will set a new adjustment limiter range for quicky tuneups.
The clips and the thread lock will prevent the needles from walking.
You can also place a bit of cut up exhaust deflector tubing over the needles to press the clips against the detents.
I've used the latter at the field as a quick on site repair to the "walking needle" problem...
