ORIGINAL: redlegtu
Aside from the reports of the Slayer's tendency to roll (which can be fixed or minimized by install sway bars), is there a something that I should be aware of before I make the purchase...........I do like the SC8, the roll cage is very cool.....not that it rolls a lot and I will not be the type that will roll the truck just for the heck of it.
I've learned one thing anything that has a tendency to roll if you drop the suspension a teeny bit that will usually fix it.(the amount you need to lower it more or less depends on model)
So if you like the Slayer I say go for it. I've noticed once someone usually brings up a name they usually see something in that model and will want it no matter what.
