RCU Forums - View Single Post - Slow 'spinning round' problem while hovering :(
Old 01-21-2010 | 03:05 PM
upona
Default Slow 'spinning round' problem while hovering :(
<font class="Apple-style-span" color="#333333" face="Verdana, Arial, Helvetica, sans-serif"><span class="Apple-style-span" style="border-collapse: collapse; line-height: 19px;"><div>hi. a new problem started yesterday on my HB king2 that i could do with some advice wth pls.
heli is hovering away, when all of a sudden the tail slowly spins round anticlockwise by itself, and im forced to land. moving rudder stick more to compensate makes no difference. if i go into a hover again, its ok for a few seconds, then round she goes again </div><div></div><div>i charged the battery today (2200 lipo) in good condition.], and squiggled the connections around on the receiver in case any had a bad contact, and at first i thought it had gone, as tail held well for a few minutes; but then it started happening again. it happens well before i have to recharge as the little plug in meter i have still has 3 green lights on when it happens, and the battery will last 18 mins, but it happens only after about 5.
whatever the problem is it seems to be effected by the battery state. cant detect any loss of power</div><div></div><div>the gyro is a HH one (skya model 'JB-06'). dont kno anything about it, as it was fitted when i bought the heli. i have no idea what the instruction manual is on about - double dutch lol. it seemed to be working ok before, in HH mode and normal. the red light comes on, and either blinks alot or stays constant at different times - i dont know if theres any significance to the lights flashing, like a fault or something. it still does this.
does the problem sound like the gyro going bad?</div><div></div><div>the blades tips are in a bad state. could vibration make the gyro go a bit crazy, or do you think its another electronic fault somewhere, say maybe the tx rudder controller? i havnt a clue where to look.</div><div></div><div>i think i have the original esky gyro so i'll fit that and see if the problem clears up. worth a try. cheers</div></span></font>
