ok can you list me the parts from the manual and I'll check it out.
John
NItro Planes
ORIGINAL: skypainter
Hi my name is Bruce, I purchased a 50cc biplane from you and are also missing 2 complete linkage kits for the ailerons, 2 wheel collars for the main landing gear, and on the tailwheel I'm missing 1- steering tiller for rudder and 1-steering tiller for rudder and 2 -steering springs.
Also on the main landing gear the blind nuts in the fusalage are the wrong thread size , I'm going to have to remove and replace them. The aluminum landing gear also had to be drilled out for the axles. Another thing I noticed the front of the fusalge where the engine mounts was not glued well and was loose. I'm going to reglue as much of the plane I can to be safe. I'm also going to replace all the hinges with a better quality robart hinge, they look weak and also going to add a couple in rudder and elevator areas.
The plane itself looks good and you can't beat the price , the plans are really vague, I have built a 50cc sukoi so I can make the changes to make it a better plane, I hope it flys as good as it looks.
skypainter
