RE: Soldering clevises
It doesnt matter to much which way you go with pushrod attachments, but you should probably have one side that is fixed and one side that is adjustable. With a solder clevis that would be your fixed point so on the other end of the push rod you would need something like an E-Z link that would allow you to slide the push rod back and forth and lock it in just the right spot.
