RE: WK-G011 & TX
Okay, here is what happens. When I push left stick forward, the pitch shaft goes down. When I pull the left stick back down, the pitch shaft goes up. The right stick forward makes the swash plate rocker rock backwards and pulling the right stick down moves the rocker forward. I compared this to my other G2 and it appears that the left stick functions are opposite. My other G2 the left stick forward gives throttle up and pitch shaft up like it should.
The rudder control appears to be ok. Move the stick left makes the slider on the shaft move right or outward from the tail and vice versa.
What do you think?
Tim
ps the pin settings on thew back are as follows: 2,4,6,8 and 9 are all on. This is the WK-2601 (non lcd) tx. with the 2701 receiver.
