RCU Forums - View Single Post - WEIRD MAGNETO PROBLEM SOLVED-Take note.
Old 01-22-2010 | 07:13 AM
j_t01's Avatar
j_t01
Default RE: WEIRD MAGNETO PROBLEM SOLVED-Take note.
You are correct in your diagnosis. The coil has two sides. One works at low speed and the other advances for high speed. We see the high side fail from time to time and cause the same situation as you describe.
Jim
