RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 01-22-2010 | 11:39 AM
  #826
MikeMayberry's Avatar
MikeMayberry
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: flyingrally
Have you had many flights with your jets and the aurora now ? I am looking at putting my aurora on my new turbine and I will admidt to being stressed.
Don't be... it will work fine! Range check video below with the turbine (running) and ECU directly between the TX and RX with no issues.
http://www.youtube.com/watch?v=62AED...layer_embedded
ORIGINAL: PlaneKrazee
Mike,
I had read some of the advertized telemetry expandability will not be incorporated into the transmitter/receiver do to parts unavailabilty. Is this true?
What telemetry will be available on current production transmitters within the next 6 months?
That was referring to the out of range function. It is unknown if this feature will be incorporated into the system.
The telemetry functionality we are planning will consist of the following:
Sensor Station (This plugs into the DATA port of the RX and all the sensors plug into it.)
Sensors: (4) temp, (2) Rpm, Fuel, and GPS for position, altitude and ground speed.
The entire telemetry package with all the items listed above (including the HPP-22 interface) will be $259.99. Smaller packages will also be available as well as each item individually.
While not every topic is referenced, please refer to the FAQ page here: http://www.rcuniverse.com/forum/m_9247572/tm.htm to look to see if any of your questions have already been answered. It's a great resource.
Mike.
