RE: 977 problems/questions
i dont even bother with setting the mah rating. just the number of cells, and the charge rate. if i were you, i would check each cell for voltage. you might have one or more bad cells which is confusing the peak detect circuit. in my case, i was able to remove a bumb cell from my 2 of 6 cell pack and make a couple of 5 cell packs. one of the cells in each pack had internal problems and was compromising the packs as a whole.
