RE: Anderson Power Pole Connectors. Have you had a failure or not?
What gage wire did you use, and what amp-rated plug did you use? I was playing with a few pairs the other day and thought the connection was pretty good, with a little 'snap' when they went together. Not sure if the thicker wire would help make a firmer connection?
