RCU Forums - View Single Post - firewall problem. need help!
Old 07-11-2003 | 10:07 AM
lownslo's Avatar
lownslo
Default firewall problem. need help!
Something else to look for as you are learning some repair procedures, is the length of the firewall bolts. Check the amount of the excess length that protrudes into the fuel tank area.
Either cut off the excess, or put a little foam rubber in FRONT of the tank too, to keep the bolt ends from rubbing the tank. This will prevent possible tank leaks in the future. .... lownslo.
