RCU Forums - View Single Post - Balanced and Blueprinted
Thread
01-23-2010 | 02:19 PM
25
DarZeelon
Apr 2003
8,913
Rosh-HaAyin, ISRAEL
RE: Balanced and Blueprinted
Quote:
ORIGINAL: blw
You can't balance a single-cylinder engine
perfectly
, but you can get it as close as possible.
Barry,
My point was that not only is a perfectly balanced single-piston engine unheard-of. 'As close as possible' is also a moot point - a far cry from reality...
As long as there is
any
reciprocating mass to balance, it will have to be counteracted with a rotating counter-balance; which essentially means no balance at all.
So, if you want perfect balance; out goes the entire reciprocating mass... No crankshaft counter-weight required either...
This is why I wrote 'single piston'. An imaginary zero-mass piston and con-rod will obviously never be.
If you can have a single-
cylinder
engine, with two counter-motion pistons; a perfect primary balance
can
be achieved... Engines like that do actually exist.
...But there is no way of converting our single-cylinder engines into them.
And trying to balance an existing engine 'as closely as possible to perfect', entails a piston that might fragment (like in the TT 1.30 - discussed here recently) and a similarly fragile con-rod...
I don't think anyone would want to go there...[X(]
Reply
Like
DarZeelon
View Public Profile
Send a private message to DarZeelon
Visit DarZeelon's homepage!
Find More Posts by DarZeelon
View iTrader Profile
