RCU Forums - View Single Post - Soldering
Thread: Soldering
Old 01-23-2010 | 08:50 PM
DaveB
Default RE: Soldering
Capt,
Just make sure your iron has enough heat to properly allow a good solder joint. I'm guessing, but I believe you would need 200w+ or similar with a torch. I'm just estimating, but for sure too little heat will result in a cold solder joint, which you want to avoid.
All the best,
DaveB
