Carbon/Composite Propeller Manufacturers
Due to a need to initiate some propeller tests pretty soo I need to find out the names, and links if possible, of all the carbon/composite propeller manufacturers. I thought I knew the name of all of them but I don't want to be limited by any memory failures on my part. So if someone makes composite props in either 2 or 3 blade dimensions and you know of them, would you mind sharing?
Pat
