RCU Forums - View Single Post - Set Up Help (PLEASE HELP)
Old 01-25-2010 | 06:38 PM
flying16150
Default RE: Set Up Help (PLEASE HELP)
Ihave a DLE111was thinking aboutreplaceing the engine, but would rather if I could drop some weight somewhere during the recover process. Not real sure of whats under the covering as of yet and not sure I can save any weight at all, I prob will upgrade the servo's though , just in case.
ORIGINAL: nmking09
Servos are bare minimum, but will fly 3D OK. If you are not doing rolling harriers. For props you are probably looking at a 26x10 thinner blade cut (xoar or so) or a 25x10. With that engine, at that weight, you are going to have a little trouble in the extreme 3D department, but it should get you by, for a while.
Good luck, post pictures when you can.
