RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 01-25-2010 | 06:56 PM
  #499
Bigboat
Default RE: New CDI - opensource project JMJ and Bigboat
The strobe send the same signal like the scr output.
Between flash you have to build a LED with a resistor (47-150 Ohm).
Wat you see on the movie is the flashlight.
To test you have switch the CDI off and remove both jumpers.
The CDI will produce 300 RPM.
If you place the jumper near the hallsensor, you get 7000 rpm.
Both jumpers on the board is normal mode, need to switch the board off and on.
