Losi Desert Truck replacement servo???
My son and I took our Team Losi Desert trucks to the local indoor track today. By the end of the day among other things I blew the front servo. The hobby shop sold me a metal geared HS-82MGas a "drop in" replacement. Well the good news is the servo saver fit. But the bad news is that it is bigger than the stock and only has one hole on each end. The stock one has two holes on the side. I've done a search and everyone recommends the HS-55 with a Losi servo saver. Most of the threads also sat that they are four wire. Mine is a three wire. Is that a Mini-T to Desert Truck change? Also how can the HS-55 be a direct drop in when it only has one hole on the side and the factory has two? Will the stock servo saver work on the 55 since it fit the 82?
