RE: Losi Desert Truck replacement servo???
not sure but i think the stock servo saver will not fit on the hs 55 and the 4 wire servo came on the mini t which is a little different then your dt . i thought the HS82 would be a direct drop in but never tried it. i can tell you that the hs82 mg servo is a servo then the stock servo or the hs55
