RCU Forums - View Single Post - trims are maxed out!
Old 01-26-2010 | 06:45 AM
rsking45
Default RE: trims are maxed out!
When centering servo arms disable the motor so you done get unexpected spool up, center the throttle stick, make sure there is no subtrim, trim. Find a servo arm that fits best to the servo so that the servo arm is 90 degrees to the servo its self. I think with the CCP you should be in idle up mode
