RCU Forums - View Single Post - crockpot method
Old 01-26-2010 | 10:12 PM
wattmeter's Avatar
wattmeter
Default RE: crockpot method
ORIGINAL: GhostRider32
Guys,
When you use your crockpot with antifreeze, do you use straight antifreeze or 50/50 mix with water? Also, if I just want to put the whole Magnum .91fs head in there without removing the valves, would it be ok? Are there any valve guides or seals that it would hurt or anything? Thanks.
Check this out http://www.rcuniverse.com/forum/m_46...tm.htm#4699477
wattmeter
