RCU Forums - View Single Post - Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
Old 01-26-2010 | 10:24 PM
SunDevilPilot's Avatar
SunDevilPilot
Default RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
Started to assemble the fuselage today. Going together as planned with no major issues.
My only concern at this point is the bending of the fuselage sides to meet at the tail. I will get this figured out before I glue the left side of the fuselage on. I need to compare the natural curve of the fuselage to the plans and see how much I need to adjust the taper at the tail to make a good joint.
The forward most former will be cut where the door is once I complete the framing and the forward bracing.
SunDevilPilot
ID:	1365335   Click image for larger version
ID:	1365336   Click image for larger version
