RE: Tam Long tiger I e
I am thinking about reversing the gears in the housings as I'm not to crazy about the pinion gear being that far out on the shaft. I have done this before on gearboxes with that issue. It is easy , you just have to press the final drive gear off of the shaft and reverse it on the output shaft to get everything too line back up. Doesn't change anything in how the box works.
