ORIGINAL: spaceworm
There are many references to the ''low'' or ''keep warm'' settings on the slow cookers or crock pots. Has anyone actually measured the desired temperature that the antifreeze should be kept at? I plan to use a dimmer control to lower the lowest temperature of the crock pot if it is higher than recommended. Comments please?
TIA,
Richard
My super scientific testing method is, if you stick your finger in it and go "Yeow"![:@] It's too hot...
